Hello guys I just wanted to ask yous a couple of questions
We have a new MGL EFIS explorer lite
And was wondering how to reset the artificial horizon as when we are flying straight and level it’s showing we are desending
Also the airspeed doesn’t kick in until 35/36 mph as we lift off how can we lower this thanks Killian
Airspeed and setting artificial horizon
Re: Airspeed and setting artificial horizon
The lowest airspeed is about 27mph.
You need to zero the ASI after installation and this procedure should be done once a year to cancel out any drift in the sensor.
You reset the AHRS to your attitude in the AHRS setup menu.
Ok thank you is the AHRS set in the air or on the ground
