Problems with MGL Central
christoph.glomski
Post by christoph.glomski »
Hello,
I am having trouble setting up MGL Central. I hope someone can answer the questions.
Lets get started:
1. I would like to convert the Sky Demon Route file (gpx format) into a format that can be understood by IEfis. The operating instructions show that this should work with the import function. When I do import the gpx file, I get a message that it has been converted to .ert file. So far so good, but this file is 0 bytes and empty. I'm desperate here, actually it's simple work to convert.
2. When I try to load the cards into MGL Central according to the operating instructions, I just don't understand a word. In particular, the ARINC424 data are simply described in too general terms. Where exactly can I find the data on the FAA / NACO website? I spent hours looking for it. Are there ARINC 424 data also for Europe? As I said, everything is described in the manual, I just need more information.
I hope that someone can help me.
Many greetings
Christoph
Re: Problems with MGL Central
Sadly GPX is not simple to convert - it gets used very differently by different vendors. MGL Central takes a few guesses depending on which fields have been defined - the only ones that are reliable are lat and long. The trouble comes into identifying the airport or other name information.
If you send me you GPX file (use the e-mail under contacts at www.mglavionics.co.za) I can have a look.
You can also do this on the EFIS itself which supports the latest known variants.
ARINC specifies a common data format for aeronautical data. It's pretty good. Usually these files can only be had via subscription from the originators.
christoph.glomski
Hello Mr. Rainier, thanks for fast replying.
I just emailed you the GPX file. For the forum I'll post the GPX text. So that the other users can also benefit from the problem solving.
With best regards
Christoph
<?xml version="1.0" encoding="utf-8"?>
<gpx xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:skd="http://www.skydemon.aero/gpxextensions" xsi:schemaLocation="http://www.topografix.com/GPX/1/1 http://www.topografix.com/GPX/1/1/gpx.xsd" version="1.1" creator="SkyDemon for Android" xmlns="http://www.topografix.com/GPX/1/1">
<rte>
<name>Strausberg - Ploetzin</name>
<number>1</number>
<rtept lat="52.580180" lon="13.915080">
<ele>76.0000</ele>
<name>Strausberg</name>
<sym>EDAY</sym>
<extensions>
<skd:level type="A" value="2000" />
</extensions>
</rtept>
<rtept lat="52.470650" lon="13.447760">
<ele>41.0000</ele>
<name />
<extensions>
</extensions>
</rtept>
<rtept lat="52.464790" lon="13.245940">
<ele>61.0000</ele>
<name />
<extensions>
</extensions>
</rtept>
<rtept lat="52.461220" lon="13.054330">
<ele>32.0000</ele>
<name />
<extensions>
</extensions>
</rtept>
<rtept lat="52.354440" lon="12.822500">
<ele>50.0000</ele>
<name>Ploetzin</name>
<extensions />
</rtept>
</rte>
</gpx>
flyarv
Post by flyarv »
I too wish to export Skydemon route and waypoint files to use in the MGL Xtreme. Is there any progress in achieving this? Thanks in anticipation!
Lcaet
Post by Lcaet »
I also have the same problem.
I have the MX1 and would like to install Skydemon, can someone help
hello, i have an MX1 and i want to put it skydemon cartography, can someone help me if possible , or do i really have to resort to packers fms? as I am young , draw on your knowledge . thanks
