MGL Engima Stratomaster
Posted: Tue Feb 08, 2022 3:02 pm
by bakerde36
My Engima has been restarting. Stays on perfect with engin off but once I start engine works ok for about 3 minutes then restarts and if I go WOT it restarts and freezes. So thinking it was a short I rewired the instrument and radac and replaced my volt regulator. It worked great for about 10 minutes warmed up plane went to wot worked for about 30 seconds and started restarting. I immediately looked at F2 and it showed 13.7 volts. I am thinking about running just the Engima to a independent battery tonight and see if it restarts. Any idea on how many amps the Engima pulls I didn't see it in the manual. My engine is 120hp Corvair. Thanks Densil
Re: MGL Engima Stratomaster
Posted: Wed Feb 09, 2022 11:58 am
Have a look at airflow - you might be charging up an isolated piece of metal that then discharges into the airframe connected to ground.
Favorite items for this are engine radiators mounted on rubber fixtures (make sure they have a copper strap to connect them to ground).
But basically this can be anything - we even had an aircraft made from carbon fiber giving issues like this - one of the wings was isolated as the metal strap intended to connect the wing electrically to the fuselage had not been fastened. This one took something like a year to figure out as you can imagine - only noticed when the wing had to come off for some work.
Posted: Wed Feb 09, 2022 1:59 pm
by bakerde36
Thanks for the reply,
Gives me something to look for. Densil
