Xtreme EFIS default page
Steevo
Post by Steevo »
Does anyone know how to make the Xtreme EFIS power on at a specific screen?
I don't use all the screens so have disabled the ones I don't need. When I power the unit on, it always starts up on the full horizon screen. I need it to startup on the engine monitoring screen. I mainly use it for all the engine parameters and the only time I ever need it to show the horizon screen is if I fly in the right hand seat seat. No matter what I do, I cannot get it to start on the engine monitoring screen unless I disable all the screens except that one. But I do want the flight screen available in case I need it. I can't find any menu option that allows me to specify a screen at startup.
Regards
Steve
Franz
Re: Xtreme EFIS default page
Post by Franz »
Hi Steve,
The Xtreme does remember the last page you were on before power off. Your internal CR2032 battery is flat, please replace and give it a try.
Regards,
Franz
Steevo
Post by Steevo »
Many thanks Franz. You know after all these years working with MGL equipment, I never knew there was a battery in the Xtreme. You learn something new every day.
