loss of CHT indication on Extreme EMS
Posted: Sat Nov 21, 2020 12:17 pm
I have an Extreme EFIS/EMS with 500 hours on a Rotax 912 uls. It uses an RDAC VD. the CHT function has stopped working. strangely enough, the unit displays the ambient temperature on both sides but will not show cht. Both cht sensors have been checked and work normally. Ground has been checked using "REF Ground" terminal. the meter shows 5 ohms between the REF/Ground terminal and the engine block gnd. K type probe is selected on setup page of EMS.
We are out of ideas. Should I send the RDAC VD unit to you guys for bench testing?
Help
Help
