Raw values from level tank
Posted: Fri Jun 28, 2024 4:44 pm
by manolo.lezl
Hello.
I've been testing and calibrating the fuel level sender. It's a 240-33 Ohm one and I have a behaviour I don't know if it's right.
Header tank is 7 liters and I get these values every 500 ml (ml:raw value):
0: 3908
500: 3908
1000: 3908
1500: 3908
2000: 3908
2500: 3908
3000: 3908
3500: 3908
4000: 3908
4500: 3908
5000: 3908
5500: 2730
6000: 2730
6500: 1938
7000: 1938
7300: 1930
The value only changes twice. Fron 0 to 5 liters, the raw value is always the same.
I have an analogue indicator too and it changes continuosly.
Any hint about this behaviour?
Thank you.
Connections are as follow:
Re: Raw values from level tank
Posted: Sat Jun 29, 2024 2:30 pm
by Olivier
Hello.
Disconnect the analog indicator. It is forcing about 6V to the RDAC FL input through it's internal resistor bridge
Posted: Mon Jul 01, 2024 1:44 pm
by andynoiseboy
Is the Fuel Level Pull Up resistor enabled on the DIP switch?
Posted: Mon Jul 01, 2024 5:27 pm
by manolo.lezl
Hi.
I've tried both positions for FL1 DIP switch.
Posted: Mon Jul 08, 2024 3:53 pm
by manolo.lezl
Olivier wrote: Sat Jun 29, 2024 2:30 pm Hello.
Oops.
I didn't saw your answer. I'll try tomorrow. Thank you.
Posted: Mon Nov 11, 2024 10:35 am
by manolo.lezl
Solved.
I installed a switch to select one or other level gauges. Normally connected to Efis and the analog one as a backup/check.
Regards. Manolo.
