Audio Warning / Annunciator
Posted: Sat Mar 23, 2024 1:22 pm
I have an IEFIS Challenger and have the audio out from ibox wired to my radio/intercom. When I go to System Diagnostics and Audio Test, I am able to hear it read through all of the different words it has programmed. However, non of the alarms actually broadcast a voice alarm to my headset. For example, I have an alarm set for low RPM. When I lower the RPM, the alarm field displays on the screen as its supposed to but no alarm is read. I have the alarm enabled +audio + box alarm out in the settings.
I also have it set up to call out 500' and its not doing that either.
Any help with setup is greatly appreciated! Thank you!
