MX1 MAP & Temp Display
pfhoeycfi
Post by pfhoeycfi »
The manifold pressure has disappeared from my main display. It was within the RPM "ring" but its now gone. Any ideas?
Also I display 8 temps, a group of 4 CHT and a group of 4 EGT. When I tap the CHT field I get a larger popup for CHT. When I tap the EGT the field turns red and and a popup for CHT (not EGT) appears (I have one RDAC XF MAP and no expansion). Is this normal?
Peter
Doylestown
Re: MX1 MAP & Temp Display
It sounds like you have a custom engine monitoring screen but there is a mismatch between the items displayed on the screen vs reality and how they are assigned in your Engine TC setup menu.
Have a fiddle in your system defaults setup menu - looks like something changed there.
