Setup is like this
iEFIS Discovery Lite
- RDAC XF MAP
- SP6
- SP7
SP6 and SP7 are detected and they flash double flashes.
for RDAC EFIS says "Rdac not available" and in info "Rdac not connected".
Tried with two different RDAC:s, same results.
CAN wires shorthened. iEFIS firmware updated.
ideas!!
iEFIS and RDAC
iEFIS and RDAC
Aki, MGL dealer in Finland
Re: iEFIS and RDAC
Is the RDAC LED flashing ?
Re: iEFIS and RDAC
Yes
RDAC shows green flash at about once a second.
SP6 and SP7 double flash. And their signal is working in EFIS.
Termination resistor (120 ohm) is at both ends of the CAN.
Removing SP7 from line does not affect RDAC:
Re: iEFIS and RDAC
order of boxes (from iEFIS) in CAN line
- RDAC
- SP7
-SP6
- RDAC
- SP7
-SP6
Re: iEFIS and RDAC
RDAC will also double flash if it is connected to an EFIS.
Since you plugged in a second RDAC with the same result - your wiring is the suspect. Have a closer look.
Re: iEFIS and RDAC
That was my problem and it's now solved. Rdac grounding was a problem. I added a wire from the engine bolt where Rdac was grounded to firewall common ground and now Rdac works perfectly.
