Blaze ARHS 4
Mmacey
Blaze ARHS 4
Post by Mmacey »
Hello
I have an Odyssey with a com extender connected to it. I also have an SP-6 magnetometer connected to the system. Does anyone know if the Blaze AHRS 4 can use the compass through the com extender?
MIke
Re: Blaze ARHS 4
No it can't.
But neither does the SP-6 work through the extender so I'm a little confused...
You can connect the AHRS 4 to the CAN bus of your EFIS system and it will pickup the SP-6.
On older systems you may have connected the SP-6 via airtalk link - in this case you can still utilize the CAN bus between SP-6 and AHRS 4.
Mmacey
Re: Blaze ARHS 4
Post by Mmacey »
Sorry I wasn't clear. The SP-6 is not connected the com extender. its connected to the Odyssey. You answered my question that I can connect the AHRS-4 to the system.
Mmacey
Re: Blaze ARHS 4
Post by Mmacey »
Ranier
o
I have installed the Blaze AHRS 4 to the Odyssey. I connected the twisted pair to the CAN/J1939 buss (CAN- for low, and CAN+ for high) using 120 ohm resistors on both ends The grounds are to the airframe. The compass is red X. The can low voltage at the AHRS is 1.4 volts and the high is 2.5.
I have tried all 4 CAN address options in the compass set up menu. The BIaze info page shows CAN ERROR. I must be missing something??
MIke
adamoconnor
Re: Blaze ARHS 4
Post by adamoconnor »
How was the SP-6 connected to the Odyssey? Did you add the AHRS-4 to the SP-6's CAN bus w/ the Odyssey? Or is the Odyssey and SP-6 talking via airtalk and the SP-6 and AHRS-4 via CAN?
Mmacey
Re: Blaze ARHS 4
Post by Mmacey »
Adam
The SP-6 is connected to the Odyssey via airtalk.
The ARHS -4 is connected to the J-1939 CAN port.
Mmacey
Re: Blaze ARHS 4
Post by Mmacey »
All
I connected a twisted pair from the AHRS-4 directly to the SP-6 with 120 OHM resistors on both ends which Adam @ Michigan avionics suggested.
Problem Solved!
