IEFIS Chalenger audio
Re: IEFIS Chalenger audio
Have you enabled the AUX input on the radio and set the input gain ?
manolo.lezl
Post by manolo.lezl »
Ooops, not at all.
I'll try tomorrow morning then.
Thank you!
manolo.lezl
Hello.
I enabled AUX input and tried different input gains, but I only hear noise although the audio transformer is installed.
I don't hear any message like "GPS available".
Noise is different when I change screens for example, as you commented in a previous post.
Best regards. Manolo.
manolo.lezl
Hello.
I have no success at all with this issue.
Can you confirm this diagram and cable shield connection is OK?
Thank you. Manolo.
sbeaver
Post by sbeaver »
It may be correct, but I don't like the look of the way you have connected the grounds/shields. As an experiment I would disconnect the shiled connections in all four places and see if you get any sound. It might might not be perfect but you should have some sound. If you do, you know what the problem is. If not, then you have to look to the configuration of the EFIS.
Next step might be to beg/borrow an oscilloscope and someone who can use it :)
Wiring should work - but as an aside the correct practice using shields is to connect them on one end only - otherwise the shield is just another conductor.
Do you have the sound file installed ?
manolo.lezl
sbeaver wrote: Sun Dec 01, 2024 6:48 pm It may be correct, but I don't like the look of the way you have connected the grounds/shields. As an experiment I would disconnect the shiled connections in all four places and see if you get any sound. It might might not be perfect but you should have some sound. If you do, you know what the problem is. If not, then you have to look to the configuration of the EFIS.
Thank you.
I tried but the noise is there.
manolo.lezl
rainier wrote: Mon Dec 02, 2024 12:46 pm Wiring should work - but as an aside the correct practice using shields is to connect them on one end only - otherwise the shield is just another conductor.
Hello.
I tried conecting only one end of the shield too on each leg: radio-transformer and transformer-efis.
The sound file is installed but it takes less than 1 second to install, when on the site it's said "The programming will take around a minute depending on the size of your sound file". The size is 349 KB.
Thank you.
manolo.lezl
Hi.
I don't know what else may I try.
- I connected only one end of the shield on both cases: on the end of the equipment and on the end of the audio transformer
- I disconnected equipments like wifi gateway, arduino, so only iEFIS, radio, RDAC and extender are ON.
I'm going to close glareshield and will not use this feature what is a pitty.
Regards.
Manolo.
