I have a Stratomaster Velocity E-1 installed in an S9. I acquired it last year and it needed some work.
A couple of the EGT and CHT pin wire connectors have broken at the wire. It looks like the previous owner soldered the wires probably after they broke. I'd like to replace the connectors properly. Any idea of the size and where I might find some?
Pin connector replacement
Re: Pin connector replacement
So, after asking the avionics guys where I work, a large aerospace company, they knew what part will work.
Molex connector. MFR part number 770146-1 Conn Socket 18-24 AWG Crimp tin.
Digikey Canada has them. PN A14096-ND
I have installed them and they work perfectly.
