oil pressure
danspeedshop
oil pressure
Post by danspeedshop »
hello I would like to know why my pressure indicates 12 lbs when stopped rotax probe 4-20ma
red wire on + and white on channel 2 with 100 ohm resistance to ground
With the engine running it works well.
tanks
Dan
sparxfly
Contact:
Re: oil pressure
Post by sparxfly »
Pull-up resistor switched ON?
Should be OFF.
Stuart
NZ MGL dealer
danspeedshop
Re: oil pressure
my dip swicht is off channel 2
