If I choose NTC type sensor for this input where do I set the range? I can purchase VDO 250, 300 and 400 deg F sensors all having the same resistance so I imagine I need to scale the temp in the MX1. Where is this done? I would imagine the same will be true for AUX 1 & 2 as well.
Please advise..
Peter
Sonex B
Pennsylvania
MX1 Coolant Temp
Re: MX1 Coolant Temp
Menu > System Setup > Engine Monitoring > Setup RDAC Probes and Senders
