Virtual aoa calibration
bvolcko
Post by bvolcko »
I enabled the virtual aoa in my discovery lite. How do I calibrate it?
iEFIS Discovery Lite
in a Xenos motor glider
gd5362
Re: Virtual aoa calibration
Post by gd5362 »
It's been awhile but I believe it is in System Setup menu. It is obviously done in flight and I think it is a cruise setting and a caution as well as stall setting. Once reaching the appropriate speeds you select each of the three to calibrate.
Glenn Davis
5362P
bvolcko
Post by bvolcko »
I have looked everywhere and cant find calibration settings. Anyone got a clue?
gd5362
Post by gd5362 »
Here are some step by step instruction that should help.
Select MENU
Then select SYSTEM SETUP MENU, Go to the second page and you should see this:
Select ENABLE AOA CALIBRATION and the screen should disappear and return to your main screen
Press MENU and go to the second page and you should see this:
While in flight you will select each of the 3 calibration functions when you reach their appropriate speeds
Glenn Davis
5362P
bvolcko
Post by bvolcko »
Thank you very much. A very clear explanation. I had not realized the firmware has been updated again. I was working with the previous version and the simulator has not been updated so I can't practice at home.
