Trig transponder abd SP12
Hotscam
Post by Hotscam »
I purchased a Trig TT21 with control unit and SP12 GPS
In the documentation it says it is not possible to use the Trig contol head so I guess I need to wire it stand alone. Wiring of the 12 to the Trig is clear but I would like to use the SP12 for the efis as well. I assume this is done by the CAN bus ? One or Two ?
Is there a wiring exemple ?
Rgds
Jack
Netherlands
