EFIS simulator
Posted: Wed Jan 06, 2021 10:59 pm
by Awalkerch750
After designing my Discovery Lite efis fuel and engine modules I exit out and the simulator goes back to the original screen. I go back in to the module and my design is still there but again when I exit, it goes back to the default screen. What am I doing wrong. Shouldn't the screen change to my new design?
Re: EFIS simulator
Posted: Thu Jan 07, 2021 1:13 pm
by PaulSS
I’m not at my computer right now, so can’t give the exact details but if you’ve created your own screens then you need to go into the setup menu and choose to display those instead of the default screens. I will attempt to provide more precise instructions later in nobody else does so in the meantime (hopefully someone like Dutchroll, who knows what he’s talking about
![🙂](//twemoji.maxcdn.com/2/svg/1f642.svg)
Re: EFIS simulator
Posted: Fri Jan 08, 2021 1:54 pm
by adamoconnor
Paul is right, you need to tell your EFIS to use those custom screen designs.
MENU -> System Setup Menu -> Standard system selections
Set FLIGHT or ENGINE or FUEL or INFO (depending on what you changed) to "Use custom screen designs"
Adam
Re: EFIS simulator
Posted: Fri Jan 08, 2021 7:34 pm
by Awalkerch750
I can't get the simulator to save my work is the problem. When I go to Module - select default engine module - make changes to suite my engine and when I exit shouldn't my changes show on the simulator screen?
Re: EFIS simulator
Posted: Sun Jan 10, 2021 9:42 am
by PaulSS
How about leaving the default screens alone and seeing if the same thing works on a custom screen.
1. Go into the design module of the default screen you wish to modify
2. Copy the 'instructions' in the left hand side of the module
3. Exit that, open the design module for the relevant custom screen
4. Paste the 'instructions' from 2. into the left side of the module
5. Make the changes you wish
6. Follow Adam's instructions for displaying that particular custom screen
Remember, when using custom screens (I don't know if the same applies to default screens as I don't use them) each page on your EFIS has its own set of screens. So if you make changes to the engine screen on Page 1 then don't expect the same changes to appear when you go to Page 2. In order to do that you would need to copy and paste the Page 1 engine screen 'instructions' into Page 2's engine screen.
