Bar scale. MGL Xtreme EFIS
Hitchflight
Post by Hitchflight »
Very content U.K. user of a new MGL Xtreme EFIS for a year.
Now using the amazing black box Enigma output facility.
Two odd issues though.
1. My fuel pressure data on the MGL Extreme display reads in the correct sense. It routinely indicates between 0.1 bar and 0.3 bar. Quite normal for my aircraft. ✔️. However on the Enigma CSV output printout the CSV data prior to spreadsheet output is shown as a single character integer only; a zero. No decimal place, essential for me and this low reading. ❌ .
What is the fix?
2. The Enigma record does not show every flight, though capture settings have not changed. I appreciate that as available data storage, fills historic data is overwritten, however this is not happening in sequence.❌
I suspect it may be something associated with date format. Has anyone experienced? What could be the fix?
Many thanks for anticipated support.
adamoconnor
Re: Bar scale. MGL Xtreme EFIS
Post by adamoconnor »
Hitchflight wrote: Wed Apr 07, 2021 2:19 pm Very content U.K. user of a new MGL Xtreme EFIS for a year.
What is the fix?
I think only Franz can answer the question #1 as he's the programmer of the units. The answer to #2 could be as simple as the clock battery in your EFIS being dead. If the clock battery is dead, each time the EFIS is booted it will default to 00:00:00 01/01/1970 until a GPS signal is acquired. This could potentially have an effect on your flight logs depending on the time from EFIS start to the parameters for the flight start being met.
Hitchflight
Thanks Adam
Yes this sounds like the answer. Many thanks for your advice.
The trouble is I have now built my panel without taking into account that an annual change battery was required. I’ll fix at the next major activity.
Regards
Bob
