Hello Board!
I’ve recently bought an aircraft with a MAG-2 and SP6 installed. The MAG2 only had version 1.0 firmware on it, so wanted to update it (mainly for the vertical compass display).
The MAG2 firmware has flashed across with no issues and tested OK with the SP6 (original firmware) plugged back in.
When I moved on to the SP6 upgrade, it didn’t go well!
I connected the SP6 testing app first to check I’d got the wiring right(!), and it was picking up data.
However, the subsequent upgrade resulted in “program write failed - please repeat”.
I did. Same thing.
Now the test app doesn’t see it, and just to be sure, neither does the MAG2 when plugged back.
Can this be rescued?
Ben
SP-6 Firmware Update Failure
Re: SP-6 Firmware Update Failure
I'm not sure I understand - what firmware did you flash into the SP-6 and SP-2 ? What do you mean with the above statement ?
I hope you did not attempt to flash SP-2 firmware into the SP-6 or SP-6 firmware into the SP-2.
The part of the firmware that loads code for an update never changes (so in case there is a problem with an update you can always try again). But I am not sure what would happen if you mix firmwares - I never tried that.
The MAG-2 successfully took the V1.10. When reconnected to the SP-6, it worked OK.
I then tried to update the SP-6 with ARMPROG.EXE, but the SP-6 failed to accept the update. Not only did the update fail, but it appears to have corrupted (or removed) the original firmware, rendering the SP-6 unusable. As it happens, I've now come to the conclusion that there has only been one update to the SP-6 firmware, and mine was delivered with that newer version - so the whole exercise was pointless anyway.
Bumping back to the top, as still unresolved!
Having ripped the MAG-2 and SP-6B out of the aircraft last year as a lost cause, I found the devices in a clear out and want to try again to get the SP-6 working again.
Today, the attempt resulted in the following:
This program is for CMPFC 190913
Application in unit: CMPFC
Version: 190913
This update program may only be used with SP-6 compass devices. This update installs in flight calibration firmware.
Attempting chip identification
Chip ID: 3B.40/04/77
Chip ID: 3B/40/04/77
Chip JTAG ID code is Cortex M3
Attempting Chip Serial Number Identification
Serial Number: SP-006-201905-2846
Programming Corter-M3 application program...
Attempting chip SIZE & REV Identification
Chip SIZE = 128k
Chip REV: 20/03/64/10
Program write failed - please repeat
Version: 190913
Chip SIZE = 128k
