Tried to use the Xtreme Data Viewer XTDV v2.0 and can't get it to work.
Throws an "invalid floating point operation" during the file load, then says its loaded, then shows nothing but one red line (the same one as when it first starts.
I load a second time and don't get the error, but it still shows nothing.
I attempt to resize the window, and again get the invalid floating point exception.
I have attached one of the files that causes the exception
Xtreme Data Viewer Fails
- 07012023.zip
- (28.83 KiB) Downloaded 464 times
