We have just installed the MX1 iEFIS in our aircraft and we have sawn that the time hobbs it not correct. Reading the user manual we've seen that we can change this over the Menu/System setup menu/Time date hobbs setup, but when we try to set any of the timers the system reset it to the old value in a few seconds. I cannot attach a video here, but I can send you the video by email if you want.
Thanks in advance.
Set Hobbs time
Re: Set Hobbs time
I've read that this was fixed on MX1 version 10, we are going to update the system and try it again, I would post here if this solves our problem.
Re: Set Hobbs time
Finally, this was solved just installing the last version of MX1.
Thanks !!
Thanks !!
