Designer: Altitude getting hidden
On a menu screen (pic) I want to place the Pressure Altitude where you see the Altimeter QNH (Special Text Item) . Reason is, I operate mostly at airfields that lack weather reporting so I would just dial in the field elevation here.
Problem is, for some reason, when I put in a field for PA it gets hidden. This doesn't happen with the QNH setting. Am I not using the dialog correctly?
Screen Shot 2021-02-23 at 4.10.09 PM.png (94.46 KiB) Viewed 2267 times
