iEFIS and RDAC
AkiSuokas
iEFIS and RDAC
Post by AkiSuokas »
Setup is like this
iEFIS Discovery Lite
- RDAC XF MAP
- SP6
- SP7
SP6 and SP7 are detected and they flash double flashes.
for RDAC EFIS says "Rdac not available" and in info "Rdac not connected".
Tried with two different RDAC:s, same results.
CAN wires shorthened. iEFIS firmware updated.
ideas!!
Aki, MGL dealer in Finland
Re: iEFIS and RDAC
Is the RDAC LED flashing ?
AkiSuokas
Re: iEFIS and RDAC
Post by AkiSuokas »
Yes
RDAC shows green flash at about once a second.
SP6 and SP7 double flash. And their signal is working in EFIS.
Termination resistor (120 ohm) is at both ends of the CAN.
Removing SP7 from line does not affect RDAC:
AkiSuokas
Re: iEFIS and RDAC
Post by AkiSuokas »
order of boxes (from iEFIS) in CAN line
- RDAC
- SP7
-SP6
Re: iEFIS and RDAC
RDAC will also double flash if it is connected to an EFIS.
Since you plugged in a second RDAC with the same result - your wiring is the suspect. Have a closer look.
Erkki
Re: iEFIS and RDAC
Post by Erkki »
That was my problem and it's now solved. Rdac grounding was a problem. I added a wire from the engine bolt where Rdac was grounded to firewall common ground and now Rdac works perfectly.
