iEFIS Lite interface to iS Rotax?
Dennis Long
Post by Dennis Long »
Ranier or anyone else, can the Rotax iS engine throttle position be shown on the engine monitor bottom bar, just like a normal engine instruments? Rotax recommends set near 50% for start up? Then 97% or less to engage the ECO mode in flight. On other brands of glass panels that can be shown on the engine monitoring screens, some as just a percentage, some with color showing on the bar graph to assist with being in the green range, that changes with engine temperature. Since it comes from the CAN Buss is it available as an engine instrument?
Thank you to anyone who can help. Dennis Long with Aeroprakt USA.
Re: iEFIS Lite interface to iS Rotax?
Yes you can place the throttle position on the display as a text item. It's a "special text" item you can select using the screen designer.
