RDAC FX oil pressure
lamber
Post by lamber »
I would like to use a 0.5 to 4.5 volt electronic pressure sensor/sender. How should I calibrate that sender on my Xtreme EFIS?
Xtreme EFIS
RDAC XF
Re: RDAC FX oil pressure
Select the 0.5V-4.5V sender in the oil pressure setup menu after selecting "Voltage type".
lamber
Post by lamber »
My Xtreme EFIS is a gen 1 and does not have a 0.5-4.5v selection, only 0-5V.
Xtreme EFIS
RDAC XF
You could still use it - it will be accurate at mid range with a rising error towards zero and max pressure but not worse than 20% at the extreme...
