Is there a document that describes the format of the IEFIS.REC file?
I am starting to use the Savvy analysis tools, but they have a limitation of only being to handle a single flight in the IEFIS.REC file, and that defeats the whole purpose of storing a multitude of flights on the IEFIS.REC file from a micro-SD card longevity perspective.
My goal is to write a parser (unless one already exists) that can split a single IEFIS.REC file into multiple .REC files, each with a single flight.
Any guidance is appreciated!
IEFIS.REC File Format?
Re: IEFIS.REC File Format?
The file format is simple: It is exactly the same data as sent through the RS232 backbox data feed (if enabled). The data is in sectors of 512 bytes each (like a disk). The first four bytes is a time stamp (applied at every sector start) and the remaining 508 bytes is the data. You can use the Blackbox datafeed document to interpret the data.
You would start by scanning for the oldest time stamp. That is the oldest sector - start here. The data here may start with the last part of a previous message so just look for the next start of message. Whenever there is a larger gap between time stamps a new flight would have started. Wrap around at the end and continue at the beginning until you processed all sectors.
I wondered if that just might be the case.
Really appreciate the direction!
Trying to get my enigma.rec file uploaded to Savvy. Might have found a bug on their website .... they're working on it. Do you have the mapping names for the enigma.rec? I'm anal about not reinventing the wheel!!!
Did you come right - I just tried the same and it returned an ERROR.Linn Walters wrote: ↑Fri Oct 27, 2023 12:08 am Trying to get my enigma.rec file uploaded to Savvy. Might have found a bug on their website .... they're working on it. Do you have the mapping names for the enigma.rec? I'm anal about not reinventing the wheel!!!![]()
Andrew
Hi Rainierrainier wrote: ↑Mon Sep 13, 2021 11:32 am The file format is simple: It is exactly the same data as sent through the RS232 backbox data feed (if enabled). The data is in sectors of 512 bytes each (like a disk). The first four bytes is a time stamp (applied at every sector start) and the remaining 508 bytes is the data. You can use the Blackbox datafeed document to interpret the data.
Just checking that the document you refer to here is the MGL EFIS Data Feed document on the MGL website?
I've been trying to process the .FLT and IEFIS.DAT files using this doc, and the only info I can match from the Primary Flight Data message is the day, month and year (the message header matches perfectly)
Would be really great if you could send something my way - end goal is a tool that gives back to the community.
Andrew
Yes that is the correct document.
