V6 backlight
karmutzen
V6 backlight
Post by karmutzen »
I've got pin 4 (dimmer) to 12v (aircraft power), expecting some kind of backlighting but there is none at all. Menu only does contrast. Any ideas? I'm trying for max backlighting - dark cockpit, bright sun, can't read the screen.
Re: V6 backlight
Backlight control has never been implemented on the V6. A pin on the connector was reserved for that function for possible use in the future.
karmutzen
Re: V6 backlight
Post by karmutzen »
Updated the V6 screen to the white lettering on black background LCD, $170. Wow, what an improvement!
gd5362
Re: V6 backlight
Post by gd5362 »
Hi karmutzen,
Where did you get your upgrade done?
Glenn
Glenn Davis
5362P
