mini RDAC update
mini RDAC update
I have updated the miniRDAC firmware to be compatible with both iEFIS normal and Lite versions.
This means it will work with all MGL instruments from the Vega and Blaze singles througth XTremes to the full-blown iEFIS.
But given the reduced inputs available and coarser resolution it is intended for and best matched to the singles or Xtremes.
An updated spec sheet is on my wbsite http://www.sparxfly.co.nz/2014/documents/rdacmini.pdf.
