EFIS Odyssey TFT-LCD Problem
gelbevierzehn
Post by gelbevierzehn »
I am using the Odyssey G2 in my Vans RV-6 and loving it.
Now I have the problem, that from time to time I get a flickering, (running) image on the TFT-screen.
The interesting thing is, that I can stop that flickering, if I press firmly with my thumb on the TFT-frame at a spot next to the ACK-Button. After I did that, the flickering is gone for a few minutes or somtimes even for hours.
So I opened the case for an inspection and what I found was the repair attempt of the preowner using lots of hot glue.
After removing the "hot glue mess" I found this little Adapter-PCB that connects the FPC-FFC Flatcable to the DF9A Connector of the TFT-LCD Screen.
Unfortunately the PCB is broken and the LCD-Connector has detached from the PCB.
My question is, is it possible to get a spare "adapter"?
The little adapter-PCB has the signature "MGL 154A".
Many thanks in advance...
Hans
gelbevierzehn
Re: EFIS Odyssey TFT-LCD Problem
Update....
Problem solved, we just "drag soldered" both connectors back to the PVB and the screen-flickering is gone (until now).
Ranger
Post by Ranger »
Hello, I have the same problem as gelbevierzehn and it also is alleviated by putting pressure on the lower left section of the Bezel.
I'm not confident of my soldering abilities and wonder are replacement parts available to fix this?
Thankyou.
gelbevierzehn
Hi Ranger,
I was also not very trained in soldering, but it is not as difficult as it seems...
If you have the same flickering effect as I had, the joints for the DF9A LCD-connector on the tiny PCB are the problem.
You can remove the little PCB very easy and the soldering with the help of magnifying glasses can be done by hand.
I used this little youtube tutorial to guide me through the process...
https://youtu.be/CVPEHgfeoGE?si=f1BKzK_OnSrPHIQJ
Good luck!!
Hans
Any workshop that does mobile phone repairs can easily reflow the connector soldering joints.
The image above showing the PCB glued down with silicon - this was not done by us. Most of the PCBs where held down with a small bracket screwed to the two small threads on the side of the actual display metal housing. On early systems we used double sided tape between PCB and display.
Ranger
Post by Ranger »
Thankyou gelbevierzehn, I'll take a look at the video and perhaps try out the method on some less important component boards like old RPi boards I have hanging around.
Rainer, thanks that sounds like a way to go if I remain less than confident to do it myself, can I take it from your reply that replacements are not easily available?
We do still have replacements here at the factory. The issue is usually getting them to the customer if not in our country. Customs procedures and courier costs from here have become a nightmare.
Since there are only two components with easy pin spacing (by today's standards) it's far more effective to take it to a mobile phone shop - ask them to use their hot air soldering station to reflow both connectors using a drop of flux. That should sort it out - quick process. Less than a minute.
There is a small ceramic capacitor that is soldered there as well - this is a 47pF on the display clock line. It's there to slightly delay the clock edge as we found some display batches where a little over critical as to the position of the edge with respect to the pixel data changing. New pixel data is clocked in about every 20 or so nano-seconds so it's quite fast.
gelbevierzehn
Hi Rainer,
thanks for clarifying the function of that tiny capacitor. I was wondering myself, why isn't a simple adapter is used in that case...
Russ_H
Post by Russ_H »
rainier wrote: Fri Jan 31, 2025 10:50 am We do still have replacements here at the factory. The issue is usually getting them to the customer if not in our country. Customs procedures and courier costs from here have become a nightmare.
Thanks for your advice Rainer. Is it possible that you could give an estimated cost for replacement module sent to the UK?
I will message you my email address. thanks Russ
