Disk Tools on Odyssey
drmud90
Post by drmud90 »
I can not find the "disk tools" on the Odyssey so I can down load the current screens. Do I have old (and obsolete) firmware?
mullokintyre
Re: Disk Tools on Odyssey
Post by mullokintyre »
If you are using the Odyssey G2 simulator, when you are happy with the screens you want to use, then go to project on the top menu.
Select Create Batch Library from Current Setup
This brings up an option to create a full script that includes the setup as well as the screen files.
Select this option to create the batch file onto the SD card of your computer.
Move it to the Odyssey and from the system Initialisation menu, select Install Task.
Option 3 on the last page is "execute Script library".
This will install your setup including the screen files.
