MX1 Alarms
pfhoeycfi
MX1 Alarms
Post by pfhoeycfi »
Is there a way to get a display and audible stall warning alarm with the MX1?
peter
Re: MX1 Alarms
Yes - requires AOA port(s) and sensor and you have a nice way to use the audio system for this (with built in sounds as well as the ability to configure your own).
You need a iEFIS Extender module which gives you the AOA sensor.
pfhoeycfi
Re: MX1 Alarms
Post by pfhoeycfi »
rainier wrote: Mon Nov 06, 2023 12:12 pm Yes - requires AOA port(s) and sensor and you have a nice way to use the audio system for this (with built in sounds as well as the ability to configure your own).
Why the extender? Doesn't the MX1 already have the AOA ports that can be used for this?
peter
