G4 Update R1 1.2 released
Posted: Thu Jan 16, 2025 12:08 pm
This update fixes a few minor issues discovered with the G4 - mostly these are cosmetic or related to drawing items on the screen.
There are also a few minor additions such as acknowledging alarms across multiple panels, controlling intercoms also from inactive panels as well as some minor enhancements to the file manager.
www.mglavionics.co.za/G4R112/exp4
www.mglavionics.co.za/G4R112/iEFISG4Simulator.exe
To update your G4 copy the exp4 file to the root of your SD micro card. Do not change the file name. Insert card and switch on your EFIS while pressing the page rotary knob in. This activates the boot loader - if it finds the file it will ask you if you want to install it. Proceed as directed. The boot loader will verify the file for validity before installation and will not continue if the file has an issue. Takes a few seconds to complete. Remove the SD card to boot the system or cycle power.
