aux audio
aux audio
So i have a V16/n16 combo I have my iefis audio from ibox sent to the input on the n16. The signal works and is wired correctly. My issue is it doesn't work correctly until I go in after every power cycle and change the volume for the aux in the settings for the n16 then it broadcast at what sounds like the full volume and there is no adjusting the volume from there any more no matter on n16 or v16. I can deal with the volume and such but I hate having to go and just change the setting for it to even make the sounds like it is supposed to. If I don't go and try to change the setting the aux audio does not work at all even though it shows it in the settings to be on.
Re: aux audio
Just the Aux, you lucky beggar
Every time I switch my system back on I have to go back into my settings and reset my intercom squelch, intercom volume, Aux volume, mute option and, most times, the frequencies. The EFIS does have a ‘keep alive’ wire and I have changed the internal battery.
