Is anyone using the Razor with N16 to monitor VOR? Does it work for you?
The Razor CDI is confusing because the deflection appears to be backwards from a standard CDI. I had assumed that this was because the display was an airplane instead of a needle. But, this is really confusing after having flown with standard CDIs for over 40 years.
However, the SL-30 CDI data coming out of the Razor is also backwards as it drives the CDI needle on the EFIS in the wrong direction, and I cannot couple it to the autopilot.
I'm looking for a firmware update to reverse the deflection on both the Razor CDI and SL-30 data.
Razor VOR CDI?
Re: Razor VOR CDI?
Well, I guess I'm the only one flying with an N16 and a Razor display.
I will start a new post to request a bug fix.
