RTC for an maxi single?
This forum is dedicated to the many variations of the MGL singles.
wmax351
Post by wmax351 »
I've got an old Flight 2 maxi single that seems to have had its RTC battery die. Not too big a deal, since it will be a backup/right seat instrument, but wondering if there is a way to replace it?
Franz
Re: RTC for an maxi single?
Post by Franz »
Hi.
Yes, the internal battery can be replaced. A bit of effort is required as the 2x rivets at the back has to be removed. The front lens is also glued which needs to be pushed out once the rivets have been removed.
Franz
wmax351
Post by wmax351 »
Awesome, that should be easy enough to do. Any idea what the battery is, so I can have one on hand?
