Send a GPS-NMEA 0183 via RS232
GeorgStein
Post by GeorgStein »
Hello,
is it possible to send a GPS-NMEA 0183 via RS232.
System:
IEFIS Lite with Extender
Thank you Georg
Bill Hertzel
Re: Send a GPS-NMEA 0183 via RS232
Post by Bill Hertzel »
In theory, by using ...
Menu>System Setup>Serial Port Routing
You can define a serial port as a "GPS NEMA Port"
I have tried to use this to send location data to my ELT but have not been successful.
I would also like to know if anyone has made this work.
Make sure you select the correct baudrate to be compatible with your ELT. You do this in your GPS and NMEA setup menu. The NMEA feed contains all required messages.
Bill Hertzel
I am pretty sure I matched the baud rates, but I'll Check it again.
Thanks.
jeffnschofield
Post by jeffnschofield »
Did you get this working? I'm having the same problem.
