Design/simulator 1.1.2.2
Posted: Wed Nov 16, 2022 4:19 pm
by royerm
Trying to set-up using version 1.1.2.2 and it's not seeing the RDAC and my version1.1.1.0 does????
Any hint???
Regards
Re: Design/simulator 1.1.2.2
Posted: Thu Nov 17, 2022 4:37 am
by Bill Hertzel
Are you getting no response from the sliders; or do you see "X"s over the gauges?
Sorry if I am stating the obvious, but have you clicked the RDAC ON/OFF button at the upper Left?
Posted: Thu Nov 17, 2022 12:54 pm
by royerm
Thank You Bill for stating the obvious, I had miss the obvious or more that
I was not looking in the right place....
Posted: Thu Nov 17, 2022 2:45 pm
by royerm
Bill.
If you don't mind and maybe missing the obvious, On the simulator my speed indicates 251 which stop me
to have access to certain option.
Can you give me a hint on where I can set it to zero????
Regards
Posted: Sat Nov 26, 2022 5:55 am
by Bill Hertzel
251 is the Max possible airspeed.
This tells me that the "Dynamic Pressure" Slider (the middle one) on the "Pressure Sensor Simulation" Window is Maxed out.
Set it to the Bottom for Zero.
Set it to about 10% for typical GA Airspeeds.
Posted: Sat Nov 26, 2022 9:54 am
by royerm
Yep that was it... Thx
