Oil temp and pressure readings different on MX1 and EMS
Stevepattinson
Post by Stevepattinson »
I have a single sender into a RDAC feeding both the MX1 and EMS. I am told the the RDAC is sending same data through to both units therefore should be same values. About 10 deg C difference between the two units. Any views on how to fix?
Re: Oil temp and pressure readings different on MX1 and EMS
Is the sensor configured the same on both EFIS?
Both set for the same units (C or F)?
Stevepattinson
Yea both set to deg C and senders set to MGL NTC
