I have an Xtreme and a Challenger. I'm trying to setup both Efis with the Rdac Xf.
The one sensor I'm having issues with is the Fuel Pressure, the sensor being a UMA 2 BAR I was able
on the Xtreme by picking TYPE (resistive) SENDER (vdo) MODEL (2bar) to work properly.
On the Challenger the options for the fuel pressure are not the same
The closer I can get is by picking the automotive(resistive) but the option for the probe
resistance are 150 or 200 Ohms that are the closest to mine(180 ohm).
So at 0 PSI. on the challenger I'm reading 0.6 PSI and I've turned my boost pump (no engine running)
and the Xtreme is giving me 3 PSI and the Challenger 1.7 PSI.
Any suggestion??? as I would like to have the proper info on my Challenger.
Regards
