I have an olderOdyssey with the G2 updates. I have never been able to a AOA bar graph on the screen. The lower left side of the screen does show the G force bar graph ( and it matches the settings I put in ). I have set the AOA cruise, yellow, and red areas per the manual, but I never see a display. I have set the type as a 2 port ( I added a 30 degree angle tube attached to the pitot tube and then used the pitot input as the level input). I also tried the single port AOA type using the bent tube and the static pressureas the second input. Neither settings show a bar graph on any of the 9 screens available ( all 9 screens are stock as the system was originally set up ).
I do get the "AOA" flashing at the top of the screen when doing a low speed stall but no other indications after setting up the regions ( cruise, yellow, and red) per the instructions. Has anyone setup their AOA displays ?
Russ
Unable to set a AOA display
