I had to find a new bug in MX1.
A short while ago I installed an Extender via Serial Port. It works fine or at least it looked like.
But with the Extender activated in the Equipment list, GPS was faulty.
First, there was no ground speed data. It worsened with no correct GPS position. A fix was reported, satellites between 7 and 10, but no change in position or any ground speed readout.
Switching off the Extender in the equipment available list and everything is fine again.
And the VSI is still senseless and simply wrong. Readout is twice the correct value.
Units setting is feet, feet per minute, km, km/h, MAP in inch HG
best regards,
Steffen
Bugs in MX1
