Hello.
I read "0" from the rpm sensor.
My engine generates one pulse per revolution, and the vendor told me that perhaps I need a 1Kohm pull-up resistor. Anybody can give me a connection diagram for my RDAC-XG?
Thank you.
Pull up resistor for tachmeter
Re: Pull up resistor for tachmeter
Solved.
A 1 kOhm resistor between tach signal from engine and 12 volts.
Regards.
Regards.
