Did you know that you can create a runway for use with GLS and display on the EFIS as you approach just with a few taps ?
Go to supplementary waypoint editor.
Tap on "Mode select" and select "ADD waypoint"
From the popup select "Make a GLS Runway"
A popup appears. Leave it on the screen.
Taxi to the first runway threshold. When lined up tap "Set Threshold 1 from GPS and altimeter".
Taxi to the second runway threshold and repeat but tap "set Threshold 2 from GPS and altimeter".
Give the waypoint a name (first line). The runway name is automatically calculated for example it may show "06/24 L:0.8Nm".
Of course the above assumes you have a good GPS fix and you have set your barometer setting to reflect the correct elevations.
You can also edit these fields yourself if you have the runway data from another source.
Once you have completed the above - tap on "Save this runway data and exit".
This runway is now saved as a special kind of waypoint. It uses the normal "long waypoint name" field to store the actual data so this type of waypoint does not have a "long name".
The EFIS continuously looks through the navigation data including the supplementary waypoints to find nearby waypoints of interest and will find the runway and display it in the same way as any other runway from a commercial data source. So it will give you run way approach guidance (the blue crosses) and you can activate it as GLS source.
It allows you to practice ILS approaches to your little farm dirt strip for example...
Make a quick GLS runway
Re: Make a quick GLS runway
Please confirm that for the Voyager simulator "Make a GLS Runway" does not exist, as it doesn't on my simulator.
Cheers Peter
Cheers Peter
Peter Armstrong
DynAero MCR-4S ZK-PSA
Auckland New Zealand
2 x G2 Voyagers, Extreme, 3 MGL Servos, SP2, SP4, SP6, SP7, 2 x V10's, MGL SP12, RDAC, I/O Extender
This functionality was added for iEFIS systems and does not exist for the older Odyssey/Voyager/Enigma EFIS systems. Sorry.
Quite a fantastic feature. I have on occasion whilst flying on autopilot, able to obtain the threshold coordinates of an outback airfield from my iphone using google earth, entering them thru this facility and then flying the. Approach VFR. Obviously have to make tripple sure you enter coords correctly but really awesome. Thanx
